What is the max size of wheels..
Old Sep 10, 2002 | 12:59 PM
E320's Avatar
I can put on 96 c class
Old Sep 10, 2002 | 01:32 PM
super3day's Avatar
1997 C230
You can go up to 19" with no problem.
Following is the chart recommended by one of the local tire shop:
195/65R15 - C220, C230, C280
205/55R16 - Sports
225/45R17 - C36 C43
225/40R18 - Plus Size
215/35R19 - Plus 2
225/35R19 - Plus 2
Old Sep 10, 2002 | 10:31 PM
E320's Avatar
thanks..
Old Sep 11, 2002 | 01:41 PM
Luwin1026's Avatar
You can go 19x8.5 all around, or if you are daring, go 19x9.5 or 19x10 in the rear - you'll probably have to flare/roll the fender and do some modifications to avoid rubbing.
I have 19x8.5 all around running 235/35/19 without any problems. I'm looking to put a 265/30/19 in the rear sometime soon.
It also depends on the offset of your particular wheel.
Hope this helps!
Old Sep 19, 2002 | 02:04 PM
cmg061's Avatar
1998 C Class 230 Kompressor
Smile
There appears to be a number of different views on this subject - a balance between good looks vs, ride quality vs harshness etc.
I posted a similar issue yesterday and the reply clearly is worth bearing in mind. I except that we are talking about two different models here but one must bear in mind practicality and ride vs simply good looks. Depends I guess on what the intended use of your vehicle is.
