Check engine light and OBD
Old Jan 28, 2007 | 09:52 PM
aychaud's Avatar
Unhappy Check engine light and OBD
I have 1999 C230 Kop. few days ago the check engine light came on. Now the car shakes at low speed and shuts down when I stop the car. I have two quesion, 1. what can be wrong and how can I fix it. 2. I want to buy OBD software for my laptop and wires to connect. What is a good software and what kind or wires I need?
Old Jan 28, 2007 | 11:14 PM
xvvvz's Avatar
C230K
Your choices run from going to Autozone and borrowing their code reader for free, to buying a code reader off of Ebay for $15-50 or buying a more indepth code reading system that involves software, a multiplexer and cables for big $$$ (Carsoft, Snap-on, etc.).
Old Feb 1, 2007 | 04:10 PM
c280rookie's Avatar
good suggestion. i'd also recommend going to a nearby autozone to borrow a reader/scanner.
sounds like your car has gone into limp mode. mine does that almost every time my check engine light is on.
there are a number of most likely problem areas in your car. i think a very common problem could be the MAF/MAS, another might be your O2 sensors, and also, it could be your ignition coil packs.
hope this helps. good luck.
Old Feb 2, 2007 | 08:10 PM
aychaud's Avatar
C230
Thanks, I will check it out this weekend and will let you guys know the result.
Old Feb 11, 2007 | 10:10 AM
aychaud's Avatar
check engine light,
I borrowed OBD 2 scaner from auto zone and three things came out. 1. problem with #2 cylender, 2. Mass air sensor 3. seconday sir system.
I changed all the plugs, took out the MAS and cleaned it . now the car will not shut at stop lights but it seems that it is running on three cylinders. any suggestions?
Old Feb 11, 2007 | 01:09 PM
xvvvz's Avatar
C230K
What codes are being displayed now after you did all that work? If you are still getting the #2 cylinder misfire code, I would begin by checking the plug wires.
