Service A or Service B around 120,000 miles
Old Apr 14, 2007 | 04:43 PM
SParkyMerc's Avatar
Old Apr 14, 2007 | 06:17 PM
atiqa's Avatar
'08 C300 Sport White w/ P2 MM & Pano
Flexible Service System - A-Service
What we do:
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
*Model year 1998 through 2006 vehicles are equipped with the Flexible Service System (FSS)
Flexible Service System - B-Service
What we do:
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
I think Service A costs around $300, and Service B costs around $600. It's been a while since I did it, so my numbers may be a little off.
I got the above information from the following link:
http://www.huntington.mercedescenter...specials.jhtml
