Dried out
Old May 18, 2007 | 11:33 PM
arslanm3's Avatar
mercedes c-class 200 1995
Dried out
Hi..
problem with my front door windows, they make sounds like they are jamed when i operate them up & down, and line marks are starting to show on the glass surface, And i think that the rubbers on the top of the door panels are alittle dried out. How can i fix this problem, is ther any kind of treatment for dried rubber or i have to change them and pay THE money?? and i dont know if they are sold separately or not !!!!!!!1 any help will help, and cheep helps are welcomed
Old May 19, 2007 | 10:56 AM
bicylindrico's Avatar
The felt lined rubber strips are replaceable individually. There may just have dirt embedded and could be cleaned out. Many of these cars needed lube put on the sliding jaw/track for groaning issues. The factory lube was minimal. If you can get your panels off then you can replace/lube any components needed. White Lithium grease works just fine. Good luck!
Old May 19, 2007 | 12:27 PM
philkwill's Avatar
2009 SL550
call or take it to an import collision shop. The dealer will give you a lot of and charge you big bucks.
Old May 19, 2007 | 06:56 PM
arslanm3's Avatar
thanks for the good tip...
Old May 19, 2007 | 06:58 PM
arslanm3's Avatar
i think i'll try that, thanx....
