wiper problem
Old Jun 27, 2007 | 01:35 PM
valexv's Avatar
02 cl203
wiper problem
my dad has a 98 c230 which the single wiper I guess can lose and stretched out and is hitting the side. anyone knows how to fix this?
Old Jun 29, 2007 | 12:51 PM
shandy2550's Avatar
1995 c220 auto
Sorry to hear about your problem, if your wiper is able to move in and out independent of the drive mechanism you will have to remove the complete wiper motor/drive unit,this link shows how ; http://members.lycos.nl/mbenz/windshield_wiper.htm ;.
There may be 3 reasons for lost drive if the motor is running,(1)the large nut on the back of the drive head may have slackened (2)the nylon gear inside the drive head is slipping on it's shaft(3)the nylon gear has stripped. The first is just a matter of resynchronising the wiper and tightening the nut, the second can be repaired by drilling through the gear and shaft then fitting a roll-pin to stop it slipping, but if the gear has stripped the drive head will need to be replaced as the gear is not available separately.
Also, make sure when you have the wiper working properly to lubricate it as shown here ;http://202tech.mkosonen.com/howto/wiper.html.
Old Jun 30, 2007 | 12:49 AM
faithful_lothario's Avatar
C280
my wiper does not move from its resting place. The motor makes a working sound but it doesnt move. how can i fix this problem?
Old Jun 30, 2007 | 05:37 AM
shandy2550's Avatar
1995 c220 auto
Lothario,could be that the motor gears have stripped, the internal gears in these wiper drives are nylon. The only way you can find what has happened is to remove the complete assembly as shown in the link in my previous post and work from there, ask if you need more information.
Old Jun 30, 2007 | 08:54 PM
C280
what would i have to replace if the gears have stripped, and how much should this cost me if i give it to a shop?
Old Jul 1, 2007 | 07:20 AM
shandy2550's Avatar
1995 c220 auto
If the motor gear has stripped it would mean replacing the motor, if it is an internal fault in the drivehead normally it would be replaced but until the assembly is removed for inspection you won't know,but it could be something as simple as a loose nut as I said in my previous post.
As far as cost, to remove strip and reinstall the assembly is about 1 1/2 hours labour but the motor is about $250 and the drivehead about $600, so if you use an MB dealer you are looking at a cost of $1000+ for the full assembly.
Old Jul 1, 2007 | 05:17 PM
valexv's Avatar
02 cl203
thanks guys for the help, gave the info to my dad
