My engine is overheating
Old Jul 26, 2007 | 07:17 AM
machadinhos's Avatar
I have a c220 d station, i´m having some problems with the engine, i live in a place where I´m always going up and down, on the past few months always when i go up the temperature starts to rise to more than 90 degrees, and starts to loose power,when i get home i cant stop the engine because the fluid will boil, Im shure that the engine does not drink water. I started by cleaning the radiator an the pipes and puted new fluid on it, I´ve cheked the heat valve, and the vents, and every thing seems ok. whats wrong with it
Old Jul 26, 2007 | 08:18 AM
Untertürkheim's Avatar
Sounds like a cracked head or head gasket except that the car would probably consume coolant. Is there pressure in the cooling lines after shutting the engine off?
