Start
Old Aug 1, 2007 | 08:43 AM
KompressorGpl's Avatar
Start
Hello! My 202 from 1997 Kompressor now as a problem: sometimes it start normally (takes a second or so); sometimes it takes about 5 or 6 seconds to work. Makes a sound like he as no gasoline in the tank, but it as! The major problem is the fact that only happens somtimes and the mecanic can't find it!
Old Aug 2, 2007 | 02:37 PM
KmprssorKid's Avatar
1999 C230 Kompressor, 2004 E500 4Matic
I have the same problem, I have a 99 Kompressor and everytime I start it (especially in the mornings) it sounds as if there isn't gas in the tank. I don't know about the 5 to 6 seconds thing.. but my key is to give it a little bit of gas and it goes back to normal. It isn't a problem, I think it's just normal. Or that's what I've been told.
Old Aug 4, 2007 | 09:41 AM
'91 300CE's Avatar
2000 C230K and 2002 ML320
Thats not normal... I don't touch the gas pedal when I start my car... no matter how long it has sat.
I don't even hold the key in the start position... I just turn it and release and the computer starts the car.
Old Aug 5, 2007 | 02:44 AM
vibra's Avatar
W123 - 1981, w202 C200
likewise do
Old Aug 5, 2007 | 02:47 AM
vibra's Avatar
you might check the OVP relay , maybe replacing its fuse will sometimes help.
it is located under the hood/passenger side . near the engine firewall .
Old Aug 7, 2007 | 08:44 AM
Thak's for the quick response!
Old Sep 4, 2007 | 08:29 AM
Cold star
Hello! The problem is the cold start when it run on lpg (gpl). If it work's on gasoline it's fine.
Old Sep 4, 2007 | 11:15 AM
xvvvz's Avatar
C230K
This is becomming a fairly common issue with the w202 Kompressors as they age. I have seen multiple threads about it but no definative solution. One person claims it was bad fuel injector nozzles but it is too soon to tell if that really helped. A few others have said changing the fuel pressure regulator helped but didn't come back with a longer-term report.
Old Sep 27, 2007 | 10:31 AM
well the problem is stil there! i'm get krazy with the car! Now is worth! Today took 6 seconds to start and in the process chock! All the lihts whent of and 1 second later it star! Help please!
Old Oct 8, 2007 | 06:02 AM
NO! I change the fuel noszzels and nothing! The f****** car is drive krazy!
Old Oct 8, 2007 | 11:57 AM
Untertürkheim's Avatar
A friend of mine is having a similar issue with a 2000 C230 Kompressor, although it is slightly different and perhaps more baffeling. So far this only occurs on the first start of the day, any other time the car is flawless.
On the first start, engine will die one second or less after starting, but it does start and run before sputtering out. On the second try everything is perfect and then on for the rest of the day. He always lets the car start itself, just turning the key to start for an instant.
This started happening just before the car was due for its 100.000 mile service. The service was done at an MB dealer, everything was changed (spark plugs, fuel & air filter, oil, trans, differential, HVAC filter, coolant, etc.) But the problem is still present. He only uses premium gasoline, and there is no indication of what could be causing this.
My thoughts were the fuel pressure regulator, maybe letting the pressure bleed out overnight. I doubt it is the fuel pump since there is no noise and the car runs perfectly otherwise.
Old Oct 9, 2007 | 12:05 AM
MBHustla858's Avatar
i'd attach a fuel pressure guage and make sure its right while its running and then leave it attached to see if it bleeds off while the car is off. if it does you've found your issue.
Old Dec 16, 2008 | 01:24 PM
Hello! The problem came back! The first start is like the engine was drunk! Take the key out. Start again and it's start fine...
Old Dec 16, 2008 | 05:43 PM
benz rider's Avatar
+1
Old Dec 17, 2008 | 08:29 AM
rfoo's Avatar
1994 C220
That happened to me before but my car isn't the same as yours. Mine is the older c220's, not the kompressor one. I change the fuel regulator and it's running good since then. It's not that much so you might want to change it see if that helps.
Old Dec 20, 2008 | 05:34 PM
Hello! Today i start the car and notice that the A/C fans work. But the A/C was tunr off and the engine was cold. Why? And buy the way if I turn the key off and start the car the fans dosent work... Can this cause a bad start?
Old Jan 12, 2009 | 08:10 AM
Helo! I clean everything: purge valve; pipes; the only thing the is left to do is change is one pipe that is connect to the intake... But my idle is not normall what can i do? Spark plugs; coils; WHAT???
Old Jul 9, 2009 | 04:40 PM
Jesus!!!! i forgot to tell!!! The problem was the head gasket!!!!
