tranny problems?
Old Oct 7, 2007 | 10:34 PM
E=MC^2's Avatar
W203X2 w201X3 W208 W129
tranny problems?
its a 1994 c280 with a little over 140k
friday i took my plugs out. they checked out ok but my wires are bad. i put it all back together and headed out......everything was..... i went on a long trip aound 60 miles that night...... everything was fine.... Saturday i turned the car on and it ran terrible i think my tranny it going bad because in first gear it stugles to get above 2k rpms and when i have the pedal all the way down it takes a second to do anthting then it revs but doesnt give me as much power as it usually does. not to mention it shifts very roughly. i hope it is just my wires.
any ideas???
thanks-Brian
Old Oct 8, 2007 | 12:00 PM
Untertürkheim's Avatar
Try changing the fluid and filter in the transmission. 8 or 9 Quarts of Mobil 1 synthetic ATF and an OEM filter and pan gasket. Just remember to drain the torque converter too.
Although your problem does not seem to be transmission related, you should service it so that it does not have issues in the future.
Old Oct 8, 2007 | 08:08 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
+1 - also , when was the last time your filters - fuel & air - were changed ?
Old Oct 10, 2007 | 09:34 PM
E=MC^2's Avatar
i need to change my fuel filter. but i just put a new air filter on.
i changed my wires and the car has been running so much better the shifting isnt as rough but it still noticeable. thanks for responding
Old Oct 15, 2007 | 08:01 PM
mber's Avatar
missing and low rpm's
Sounds to me like an air leak between the airflow meter and the throttle body. I had a similar problem.
Check the clamp and hose at the back side of the MAF , the clamps at the throttlebody. These can be overlooked easily, they needed to be loosend to get to the plugs and wires.
Brian
