Engine Wiring harness
Old Nov 19, 2007 | 04:31 PM
rmt6668's Avatar
Hi
Is there a manual how to replace/remove the wiring harness?
What type of wiring to replace that bio degradable stuff?
Old Nov 19, 2007 | 07:50 PM
rmt6668's Avatar
HI
I'm confused. This link :-
http://www.detali.ru/cat/oem_mb2.asp...SGR=160&SGN=05
Which of the 3 diagram is the engine harness where there is 3 connecter onto the engine?
Old Dec 8, 2007 | 06:59 PM
rmt6668's Avatar
Hi
Attached the Engine Wire Harness 202 540 3132. The insulation falling apart after 10 yr, some exposed are touching each other.
What type wire should I use? Is it by the gauge or the amps? I went to autobarn, repco & supercheap auto their automotive wire are firmer unlike dicksmith, tandy, jaycar, more electronic. May not be heat resistant.
Attached Thumbnails Engine Wiring harness-harness-inspection.jpg   Engine Wiring harness-wire-disintergrating.jpg   Engine Wiring harness-wire-disintergrating-2.jpg
