Plug Replacement
Old Dec 21, 2007 | 04:33 PM
99MBSport's Avatar
1999 C280 Sport
Plug Replacement
Is there two plugs per cylinder and where is the #6 Located on a c280 sport? Thanks
Old Dec 25, 2007 | 01:53 PM
Substance's Avatar
2 plugs per cylinder total of 12. you have to remove the tube that connects the air box to the engine. you dont need any tools for that. you should be able to reach all the plugs on this side. the other side you shouldnt have problems with the first 3 cylinders, last one will be a bit difficult. I suggest you buy the tool for removing plug wires. autozone sells it for like 8 bucks.
then its easy job. use anti-sieze for the new plugs. the total job should not take more than 2 hours. make sure the engine is cold and once the old plug is out make sure nothing goes in to the cylinders. if your wires are old, i suggest u replace the ignition wires as well while you are at doing the plugs. for the plugs you will have to remove all of them anyway.
i removed coils before i even removed the wires, it made my job easier.
good luck
Old Jan 24, 2008 | 06:43 AM
95280's Avatar
1995 C280
Out of interist and being a noob is it a inline or v6 version?
Old Jan 24, 2008 | 12:10 PM
xvvvz's Avatar
C230K
Since the original poster shows they have a 99, a 99 would be a V6.
