Changing corner lights
Old Dec 31, 2007 | 12:00 AM
nitrotiger1's Avatar
1996 c280
does anyone know how to change the corner lights to clear ones? I have the ones but I can't figure out how to get the old ones out. Anyone?
Old Dec 31, 2007 | 11:40 AM
skyking1981's Avatar
1994 c280
changing turn signal lights
The lights are held in by two tabs connecting it to the headlight and one tab to the fender area. Reach behind the light into the fender area and you will feel a "tab" that will move away from the fender. The entire turn signal assembly will tap straight out with a gentle tap or two from your hand. If you look at the tabs on the new one you will see exactly what I mean. Let us know how it goes!
Old Dec 31, 2007 | 04:01 PM
BrabusCClass's Avatar
GL450, Sienna SE
Use a flathead and push the tab and it comes right out. You can see it from the top looking down. There is a small hole where the screwdriver can fit.
