Increasing the pressure in the braking system
Old Jan 27, 2008 | 12:19 PM
KompressorGpl's Avatar
Hello! It's possibel to increasing the pressure in the braking system?
Old Jan 27, 2008 | 02:58 PM
Dr. C36's Avatar
1996 C36 AMG
Bleed the system, make sure there are no air bubbles.
upgrading to stainless steel brake lines will also maintain higher pressures under heavy braking b/c the lines do not expand as they heat up like older rubber ones.
Old Jan 27, 2008 | 03:55 PM
Ok thanks! But i have a c180 and the pedal is more "hard". The thing is that on my C180 i dont see oil on the out side of the deposite. Strange?
Old Jan 30, 2008 | 09:02 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
so are you saying the pedal is hard to press?
Old Jan 30, 2008 | 09:04 AM
tanktube67's Avatar
I see, the pedal feels spongee
1. check the brake fluid
2. blead the system
Old Jan 30, 2008 | 12:42 PM
Yes the pedal feel spongy... Some told me to change the brake pump.
Do I have to do that? I change the brake fluid and bleed...
