line removal from pse
Old Jan 27, 2008 | 08:11 PM
skyking1981's Avatar
1994 c280
How do you remove the air lines terminating at the PSE? Do they just pop off with a tug?
Old Jan 27, 2008 | 08:29 PM
carson357's Avatar
2005 C-230 Sport Sedan
they should pop off, i use an 8mm open end wrench on the fitting to gently pry. if they seem stuck make sure they werent glued on by someone
Old Jan 27, 2008 | 09:15 PM
1994 c280
how many lines?
On my 94 c280 my PSE has 8 or 9 lines but all the ones I see on eBay only have 2 or 3...any ideas why,,,upgraded pump maybe?
Old Jan 28, 2008 | 01:44 PM
1994 c280
air line distributor
There was a removeable line distributor which is why my pump looked so different from those on ebay. Still there are SEVERAL part numbers associated with that pump so be careful when replacing.
