camfollower- shim dropped pls help
1) the cam clamps where loose so tightened them up. ( quietend it a little bit )
2) one of the chims- camfollowers has dropped and there is a 4mm gap easy where as the rest have 1mm if that
what causes this? could the valve be slightly bent or could it be shted up with carbon so as not closing properly?? or coulod it just be a bad shim and needs replacing ??
i have put loads of redex into gas tank and also into piston chamber still hasnt fixed it tho.
any help would be mint thanx in advance macca
