How to change the cooling fluid?
Old Apr 6, 2008 | 12:35 PM
KompressorGpl's Avatar
Hello! I have a C200 and I want to change the cooling fluid. Can someone please post a how to (with pictures)? The cooling fluid what is your adveci? From the dealrship? Water with antifreeze?
Old Apr 15, 2008 | 02:01 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
First, do you think you can keep your posts in a manageable order? You post new threads for ish that is of the same subject matter. Keep it manageable.
You should have a petticot on the bottom of the radiator. Open, drain, and fill from the coolant reservoir.
E
