help with instrumental panel removal
Old May 15, 2008 | 01:54 PM
w202305's Avatar
c230 kompressor 1999
im trying to remove my instrumental panel to replace one of the bulb inside
can sone one help me!
how can i remove the panel
here is a pic of what im trying to remove
Old May 15, 2008 | 02:17 PM
99MBSport's Avatar
1999 C280 Sport
Take off the lower panel that covers the brake pedal and then you need to remove the lower dash board. There are several screws in the panel. One is by the key area. It's a hole that has a screw way up inside. Then the panel snaps off. Be careful not to break the tab on the left side. You have to roll the dash down (lower portion) and remove it. The bulbs are accesable better if you use a small mm socket and extension. .It sounds complicated but on a 1-10 it's about a 3. Be sure to check them all b4 youput it all back together. I just did my 99 c280 sport. Better to not snap out the speedo head assy. If you distort the surround it will look like crapola and be a reminder til ever.
Old May 15, 2008 | 06:09 PM
xvvvz's Avatar
C230K
If you mean the instrument cluster, it is even easier:
http://www.pixelfehler-behebung.de/b...bauenglish.htm
http://www.club202.com/forums/showth...hlight=cluster
