W202 some problems.......
Old Sep 12, 2008 | 06:38 PM
rustee's Avatar
1996 C280
hi guys i have a few problems with my car and yes i did run a search but found nothing conclusive.......my key is stuck in the ignition sometimes its easy to take off and sometimes i cant get it out at all!!! is there an easy fix for this problem?!?! also there is a cable from that goes from the fuse buse in the engine bay and runs all the way to the fan in the front and its loose its not even connected properly but if i connect it or make connection the fans will turn on?!?!?!? whats up with that?!?!? will post pic later
thank you
