Hard Engine vibration in drive.
I have some hard vibration in drive and nothing in neutral. I pulled the codes and the code for a cam shaft balancer came up. If that was the issue shouldn't it be vibrating in neutral as well?
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
What model/engine do you have? Milage?
Does the engine misfire?
Probably the engine mounts and transmission mount, maybe be ignition leads if you have a V6
