Front left and right suspension not balance
Old Oct 24, 2008 | 02:20 PM
Lee Man Fai's Avatar
W202 C230 Kompressor
My W202 C230K with AMG spring+Blisten damper
I found the gap between the fender and tyre of left and right is not balance.
There is 15mm difference, front right is lower than front left 15mm.
The gap in rear wheel is almost same.
That 15mm difference is acceptable or not?
I have jacked the car and check all the bushing are alright.
Is is possible the damage of the spring pad of front right, so causing front right is lower?
Thanks,
Ja (from HK)
Old Oct 26, 2008 | 12:13 AM
PhilfromPA's Avatar
300E 3.2
Don't know who did your suspension work but make sure they didn't accidentally leave the old spring pad in place and put another on top of it (actually below it). Sounds strange but I've heard of other 202's running into the same problem.
Other than that you really want to make sure your spring is sitting correctly on the perch & butted tight to the end of the pad. Settling could be a factor but prob not to that degree. Really sounds like a spring pad though.
Old Oct 26, 2008 | 02:44 AM
Thanks,
I will go to garage tomorrow and disassemble the suspension, and take it out to check the spring and the pad problems
