Time to Rebuild
Old Feb 15, 2009 | 03:44 PM
$tallion's Avatar
97 C28
Time to Rebuild
Looking for ideas for modifications on block pistons headers u name it i want to hear from you!
97 c280 sport lets goo!!!
Old Feb 21, 2009 | 07:45 PM
23K's Avatar
23K
Hey,
Balance everything,leave all internals stock...invest in decent external engine mods.consider stronger internals only if you manage to ever break them =).
Paul
Old Feb 22, 2009 | 10:36 PM
$tallion's Avatar
97 C28
Latest
were talking about installing lighter pistons new pistions cam bearings and other bearings it seems at this point of 165000 its time to change every bearing ... Head gasket was done around 100k so well wait on that and the valve cover gasket will be changed allong with oil level sending unit and lower ball joints and lower tie rods shocks are still original and to be honest not bad eibach springs nice n low shocks will be replaced sooner than later bilstien sports
later
Old Feb 23, 2009 | 01:50 AM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Why not just do a C36 swap? Just a thought
Old Feb 23, 2009 | 04:35 PM
$tallion's Avatar
97 C28
cause the only diff
is an ecu format and a bore job i'll actually get 400 horse oppose 236
Old Feb 28, 2009 | 03:50 AM
23K's Avatar
23K
You will need a new head gasket regardless if you pull the head off.
what pistons are you planning to use?...compression changes if any?
Omey,Low boost 3.6 would see some nice results,i should have done that instead of my 4. hindsights awsome=)
Old Feb 28, 2009 | 10:36 AM
$tallion's Avatar
97 C28
More to be revealed
Well still undecided I want everyone's recommendations first the word was go with a lighter piston head gasket was changed at 120k now at 164k car is mint
running rich at moment awaiting dyno tune on monday
Old Mar 4, 2009 | 01:53 AM
23K's Avatar
23K
So how did the dyno tune go?
Well for what its worth be it worth anything at all,Use standard mercedes rings with what ever piston you use,talk to only engine builders who have re-cond or upgraded mercedes engines many times.dont buy the lightest piston just because its light,light doesnt benefit you if you have to pull them out after 10k's due to slap or excessive skirt wear.
Goodluck with the project.
Old Mar 6, 2009 | 10:32 AM
$tallion's Avatar
97 C28
Heard
heard
