'98 C280 Sport Power Seat Issue - Driver's Side
Old Apr 11, 2009 | 08:34 PM
T-Roll's Avatar
2001 E55 AMG
The front portion of my driver's side power seat is angled too far down, and the power control on the door does not move the front part of the seat any longer. It feels like the front-left portion of my seat is drooping a bit. The back / recline adjustment still works fine. Is my problem likely caused by a bad switch or possibly a fuse that burnt out? Thanks for your input.
T-Roll
Old Apr 12, 2009 | 03:05 PM
$tallion's Avatar
97 C28
Try this pop the trunk pull the carpet up a bit behind the battery well no just check the fuses in the trunk you'll see under the cap theres a diagram replace the ones that you feel are giving you trouble and go to autozone get the right fuses for instance mine takes a 15 for the window i threw a 20 in ok as long as there for the vehicle your good..and even though they look good change em out anyway...
