2 problems..head gasket leak & dead instrument cluster
Second, after having the car about a month or so I switched to Mobil 1 synthetic and within a week an oil leak developed which has gotten steadily worse. Seems there was a defect in 97 C280 head gaskets that allows a leak to develop on the front of the engine by the timing chain cover. Without spending $1500 to $2,000 to fix an oil leak any suggestions on alternate repair? Any help on both is appreciated!
as I was reading your comment I noticed an ad for "Steel Seal". You might check it out at www.steelseal.com for your problem..sounds good but who knows?
Good luck
Where is the oil leak? If it is just a valve cover, that is easier and cheaper than a head gasket. Are you seeing oil sludge in the coolant reservoir?
