"floating" idling
Old Feb 8, 2003 | 09:05 AM
aroppi's Avatar
1994 C280
"floating" idling
hi!! i'm a new comer and i've a question about my 1994 C280.
recently i found that the idling rpm of my C280 is not so stable. especially when i drive my car slow, say, 20-30km/h in the car park. once i stop pressing the gas pedal, the idling rpm will "float" +/- 200rpm!!! i've changed the spark plugs, coils, air filter and i've cleaned the Mass air flow sensor. well, improved a bit!!??
what i should do??
Old Feb 8, 2003 | 01:42 PM
DougandhisC280's Avatar
2008 SLK-280
If you read in some of my earlier posts (K&N filter, notice a difference?) you will see that cleaning the air mass meter doesn't always do anything. I would just change it out entirely. They are about $190 at www.bimmerzone.com . You may want to get the diagnostics run on it first just to make sure that is actually your problem.
Old Feb 9, 2003 | 02:25 AM
aroppi's Avatar
1994 C280
thanks for the reply!!! well, just wanna know whether this car has the idling sensor or not coz' i know sometimes the Bimmers will have such a problem due to the malfunction of this sensor.
