Sep 17, 2009 | 07:39 PM
check this out my temp gage is goiing from 80-85 all the way up to 120 and back down.. wassup with that it only happens while i'm driving.
i checked the antifreeze level cap its fine. added a little water..
i'ma do a flush in about the next coulpe of weeks here what would u recommend the flush go like
Reply 0
Sep 19, 2009 | 07:22 AM
maybe your thermostat is going bad?
Reply 0
Sep 22, 2009 | 01:17 PM
hows about coolant water wetter what kind of water.
what coolant would you guys say i use
Reply 0
Sep 23, 2009 | 09:54 AM
I think I had a similar problem with my car years ago.So,check when the engine is warm 80-90 degree temp,if the ventilator is working/turning.If it is not,then maybe the ventilator is broken or the ecu of the ventilator(electric part)needs repairing/replacing.It cost me about 200 euro(160 the part+40 the work).I hope you find the solution to the problem.bye ...a greek friend...
Reply 0
Subscribe
Currently Active Users (1)
