question bout bilsteins
Old Feb 26, 2003 | 02:32 AM
J__'s Avatar
J__
2012 C200 CGI
hey guys~!
i finally get the shocks from cali.. so i took out the bilsteins and attempt to install myself... the shocks have 2 rubber washers and pad thingys.. my question is do they both go underneath the car or do one go under and one go over(inside the hood under the 2 locking nuts)
(Tp???)
thnx!!!
Old Feb 26, 2003 | 11:31 AM
DougandhisC280's Avatar
2008 SLK-280
The rubber pad/bushing goes on top.
Old Feb 26, 2003 | 02:34 PM
J__'s Avatar
J__
2012 C200 CGI
oh ok
so one goes on bottome and one goes on top rite?
thnx thnx
ps. are all 4 shocks the same? the front and back?
Old Feb 26, 2003 | 04:05 PM
tpliquid's Avatar
too poor now
front longer rear shorter. makes sure u got the right ones b4 u install alright@@@
Old Feb 27, 2003 | 03:22 AM
J__'s Avatar
J__
2012 C200 CGI
hmmm.. i should chek that lol
thnx
how about the rubber bushing?
Old Feb 27, 2003 | 01:39 PM
2008 SLK-280
If I could see a picture of it I could tell you. I thought there was only one bushing. It goes on top inside the engine bay. Just install them the same way the old one's were put on. If I remember right, you don't use all the pieces they give you since the shock fits several other cars.
Old Feb 27, 2003 | 02:24 PM
J__'s Avatar
J__
2012 C200 CGI
there is
1. a rubber cover over the shock.. i htink that goes under the car
2. a smaller rubber washer (like a mini thick donut)
3. 3 metal rings
4. bolts etc etc
thnx!
Old Feb 27, 2003 | 05:21 PM
2008 SLK-280
Allright. Starting from left to right in this picture I will tell you where each part goes. We will first talk about the top. The black rubber one on the very left goes on first. Second, put on the metal washer. (the big one) Next put on one of the nuts and tighten it down good. After that put on the second nut to lock it in place. Some shocks come with just one lock nut. It has plastic in the middle. If this is the case, you only need to put on one of those. At the bottom of the shock, first slide a small washer on the bolt. Second, put the shock in place. (where you install it on the car) If you are doing the front, it helps to turn the wheel in one direction. Slide the bolt through the bottom of the shock. Slide the last small washer on and then tighten the nut on top of it. That's it. Make sure you got everything good and tight. Hint: When trying to take the bottom bolt off and on it help to jack up the car to the neutral position so there is no up or down pressure on the bolt. You should be able to slide it in and out with you hand. You can use a hammer if you get mad at it. Whew, I should become a moderator.
Old Feb 28, 2003 | 02:54 AM
J__'s Avatar
J__
2012 C200 CGI
oh thnx! very detailed ^^
but i have extra rubber things.. on well i'll figure it out
thnx guys!
Old Feb 28, 2003 | 01:40 PM
2008 SLK-280
You probably won't need the extra parts. They may be for a different car. I'd hate to see what would become of a company if they only made 1 shock for 1 car.
Old Mar 1, 2003 | 07:19 PM
J__'s Avatar
J__
2012 C200 CGI
got it done! took 5 hours
thnx guys!
Old Mar 2, 2003 | 12:25 AM
J__'s Avatar
J__
2012 C200 CGI
one more question, cuz i used new bolts on the lower joint of the shock, should i grease it?
Old Mar 2, 2003 | 12:58 AM
tpliquid's Avatar
too poor now
no
make sure there tight.
or else they fall off u die
Old Mar 2, 2003 | 05:04 AM
J__'s Avatar
J__
2012 C200 CGI
Old Mar 2, 2003 | 12:55 PM
soldsep's Avatar
87 300 E
Originally posted by tpliquid
no
well if you hear rattling noise u know something's not tight. But yea tighten everything trill u can not tighten any more.
Old Mar 2, 2003 | 07:32 PM
J__'s Avatar
J__
2012 C200 CGI
kk thnx gusy
D@mmit!!! wen i was installing shocks, i noticed b4 i took off my shocks that my left rear was lower than my right rear. i thought it was because of the shot shocks... but after i changed them, the left was still lower.. .like by 1 cm...
does anyone knw what might cause it?? they were even wen i first ahd my H&R installed...
Old Mar 2, 2003 | 10:32 PM
2008 SLK-280
This is incorrect. Tighten the bolt 3/4 of a turn before THE BOLT breaks off. Get it, it's a joke. Don't actually do this.
Old Mar 2, 2003 | 10:37 PM
tpliquid's Avatar
too poor now
i duno how it will break off? caus i tighten them very tight..
Old Mar 2, 2003 | 10:40 PM
2008 SLK-280
it's a joke.
Old Mar 2, 2003 | 11:47 PM
soldsep's Avatar
87 300 E
lol yea u gotta actualy torque it about 12.9 lbs no more no less or else you die.
Old Mar 3, 2003 | 01:19 AM
J__'s Avatar
J__
2012 C200 CGI
i used torque wrench they r about 150lbs each
