vacuum pump
Old Sep 28, 2009 | 04:42 AM
happymerc200's Avatar
1998 C200
vacuum pump
Does anyone know where the vacuum pump is located for the headlight adjustment????, it used to work then just stopped, now I have also heard there is just one pump for everything, which is a good thing, because that means it is then working
maybe some one has other ideas why my headlight adjustment does not work????
oh it is not the switch
Old Sep 28, 2009 | 11:49 PM
xvvvz's Avatar
C230K
The pump on US cars is located in the trunk on the starboard side of the car (right if you are sitting facing forward in the car) back behind that side's trunk liner piece.
My guess is that you have a vacuum tube problem if everything else works. Either it has split along the way, become disconnected at either end, or a connector has gone bad.
Old Sep 29, 2009 | 12:48 AM
1998 C200
XVVVZ Thank you for your reply , I think you are correct, I found a pipe that has come out SOMEWHERE and have NO idea where it goes........it is in the engin bay right at the back by the winscreen at the back/top of the engin " if you are looking from the front it runs from left to right" and on the right side it is open but dont know where it must be plug into
it is a white pipe if that helps anyone
Old Sep 29, 2009 | 02:01 PM
MercBimmerman's Avatar
97 BMW 740iL / 00 MBZ E320 4MATIC
Could you take a photo of it?
Old Sep 30, 2009 | 03:38 AM
1998 C200
Thanks for all the help, I found it, I turned on the car and felt around where I thought it might be, and felt the air, you can't see the pipe it must go on, it is right under everything you need to feel then plug it in.
but I'm happy again and thanks again
Old Sep 30, 2009 | 12:52 PM
glad it worked out
