Noise from the propeller
Old Oct 1, 2009 | 07:58 AM
rfoo's Avatar
1994 C220
Just notice that when I put my car on reverse I hear this noise like a fan blade hitting something and the sound goes with the speed of my car. The more I go faster the faster the sound go and vice versa.
Also I notice that at around 60 miles, I smell exhaust coming in inside the cabin when my A/C is off. Not really sure if it's exhaust or like a rubber burning. I figured this two is connected since something might be rubbing against each other that's why I smell something burning.
Old Oct 4, 2009 | 04:56 PM
atppilot's Avatar
Answer
Sounds like your transmission mount is going. It hits the insulation at the top next to the flex coupling on tailshaft. I had the same thing happen. Replace the transmission mount, but don't forget to remove a little of this insulation. It's tough to get to but take you time and you will get it.
Old Oct 5, 2009 | 03:37 AM
rfoo's Avatar
1994 C220
Hey thanks for the advice, I'll go and check that mounting see if it needs replacement.
