Headlights go down upon acceleration
Old Oct 28, 2009 | 01:41 AM
n.rosenfeldt's Avatar
Mercedes Benz C230 T Kompressor
Hello all.
First of all, thank you very much for all the help, I have received just by reading this forum :-)
I own a MB C230 T Kompressor from 1997, 385.000 Km on the dial.
I have had my share of problems with the engine, however they have been solved now.
The only problem, I actually have right now is, that the headlights are lowering, when I accelerate the car. If I let go of the pedal, the lights go up again to normal position.
I reckon that it is a problem with the vaccuum..
One vaccuum hose was broken, and this has been repaired. When that was broken, the lights just went down and stayed there.
Could anyone help me as to where to look for any leaks. There are no hissing noises on the inside of the car (e.g. from under the dashboard, as there was when the hose in enginecompartment was broke..)
I am about to sell the car, but any help would be appreciated, as I'd like to sell a working car :-)
Regards
Niels Rosenfeldt
Gilleleje, Denmark
Old Oct 28, 2009 | 02:51 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
The problem won't be a vacuum leak, it will be a non-functioning check valve in the system. I would just go to a auto parts store and buy a small check valve and put it on the vacuum line from the manifold. problem solved.
Old Oct 28, 2009 | 03:41 AM
And that's it? Will this new check valve then take over the function of the non-functioning check valve? .. Sounds too easy to me :-)
I will try this later today.
Old Oct 28, 2009 | 08:43 AM
Ausmbtech's Avatar
yep, thats exactly right
Old Jul 14, 2023 | 08:47 PM
Belloum's Avatar
w202
Hello, i own a w202 c1.8 1996 m111.920 and i have the same problem . what kind of valve are you talking about . Can someone guide me more ? serial nunber (how loooks like) of valve and location in car . Thank you .
