Burning Oil - Help!
1998 C280-Sport
Burning Oil - Help!
Hello. I am having a very severe problem with my engine burning oil. I have only found one post related to my exact problem, http://www.benzworld.org/forums/w202-c-class/1342617-c240-1999-white-smoke-losing-oil.html[/URL] However this thread has no results from the suggestions. I honestly think the last section about the rear crank seal gallery is the problem. The seal there is leaking slightly.
The problem happens whenever I want to accelerate or going up a hill. A white cloud of smoke is puffed out my exhaust for 3-6 seconds. I had the engine cleaned and the valve seals were also changed. Any ideas? Thanks for the help.
Matthew
Matthew
What engine are you running, the V6?
Ran across this, might be a little help
http://www.autohausaz.com/mercedes-a...-pressure.html
1998 C280-Sport
Yes there is the V6 engine in the car. My mechanic has done a compression test but says that a leak down test will not reviel anything else. The compression is excellent. So wierd. Thanks.
Matthew
Matthew
Have you gotten a second opinion from another mechanic, or you have complete faith in this one?
