advice on 96 C220
I am about to buy a 96 C220 that I found today, 72k miles, seems to be in good shape as far as I can tell... and could use some advice.
I am going to have it checked out by a mechanic to be sure, but was curious if there were particular areas that I should be concerned about...
... or if I am about to make a horrific mistake by buying this car, please stop me!
Also there is no maintenance record or owners manual with this car, is a manual available? And in the absence of a record, should I assume that none of the recommended things have been done and have them all done now... or is the damage already done?!
Thanks in advance,
Jim
-s-
The car will most likely be very reliable, but seeing how it is a Benz, if something does go, it will cost you (i.e. I believe the PSE pump was somewhere around $700, if not more).
Jason
