SRS Battery problems
Old Dec 4, 2009 | 03:29 PM
E=MC^2's Avatar
W203X2 w201X3 W208 W129
My battery has been dying the colder it gets this year. I have had to jump it twice. The battery is very old and I do not drive far but when I do I put a decent load on the alternator so im not surprised the battery has declined this winter.
Well last night it died I had to jump it to get home when I did so one of my tail light blew out. No big deal but maybe related.
This morning It was dead not a big deal I was expecting it to happen, I replaced it without much hassle. Then when I turned the car on with the new battery installed my SRS warning lamp stayed on and has done so all day.
Should I hook up a scan tool to find out where the problem is or did I blow a fuse while replacing the battery? Maybe the srs computer needs to be reset when the electrical connection is removed?
What do you guys think?
-Brian
Old Dec 4, 2009 | 04:34 PM
xvvvz's Avatar
C230K
You may have to go to someone with a professional scanner tool. The SRS usually cannot be reset by a common OBD II tool. Try disconnecting the battery again for 30 seconds but I would not get your hopes up.
Old Dec 4, 2009 | 05:04 PM
E=MC^2's Avatar
The dealer I called recommended that I turn the wheel from lock to lock to see if the clock spring would send a signal or not. Could A blow fuse trigger the srs light?
Old Dec 4, 2009 | 05:56 PM
xvvvz's Avatar
C230K
Heh... I think he is mixing up ESP with SRS. Turning the steering wheel lock to lock is a way of resetting the ESP function.
Old Dec 5, 2009 | 11:44 AM
E=MC^2's Avatar
I disconnected the battery for awhile and tried the wheel thing No luck. I will bring it to school monday and hook up a scan tool. We have like ten but im sure none of them will work but ill try.
what is the most common cause for srs light to come on?
