What size wheels?
Old Dec 14, 2009 | 05:27 AM
Vaicake's Avatar
1995 C280
What size wheels?
What size wheels will fit my 1995 C280 Luxury...
Example: 19x8.5, Would that fit?
Any help would be great!
Old Dec 14, 2009 | 10:27 AM
LawRens's Avatar
43
Offset? tire size? staggered fitment?
19 x 8.5 will be a tight squeeze on the front, and fender roll/pull may be necessary unless you're lucky with perfect fitment. for the rear it should be fine.
Old Dec 14, 2009 | 11:30 AM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
Here is the wheel and tire calculator.
http://www.bigcustomwheels.com/info_specs.jsp
Just enter your original size on the left side and whatever you want on a right - it will tell you results.
Good luck.
Old Dec 14, 2009 | 12:34 PM
Vaicake's Avatar
1995 C280
That is a little confusing..
I'll just give you guys the link:
http://www.myhotmercedes.com/Mercede...eel_Set/549434
Let me know, thanks
Old Dec 14, 2009 | 12:58 PM
aeggroup's Avatar
What is the original size of your wheels and tires ?
Old Dec 14, 2009 | 01:07 PM
Vaicake's Avatar
1995 C280
Its oem, looks like this: http://www.cannillomotorsports.com/p...0/P1013290.JPG
I don't wanna go out in this blizzard right now, so a picture will do. haha
Old Dec 14, 2009 | 01:33 PM
aeggroup's Avatar
Do whatever you want......
Good Luck...
Old Dec 14, 2009 | 01:43 PM
Vaicake's Avatar
1995 C280
well, its those rims, I BELIEVE its 16x7.5. the tire that I have on it right now is 195x65
Old Dec 15, 2009 | 12:04 AM
Vaicake's Avatar
1995 C280
Anyone?
Help would be appreciated..
Old Dec 15, 2009 | 08:32 PM
Frank Castle's Avatar
C43
I put 17" on my 95 C220 . They fronts rubbed when backing up. I was "told" I could go 18, glad I only went 17.
The larger the wheel, the thiner the tire. Makes for better cornering but may stiffin your ride up feeling more bumps in the road (less tire there)
5x112 is your lug pattern. Look up and be aware of your off set.
ALSO:
You may need shorter bolts when using after market wheels. The original spec ones may turn out to be to long, screwing into the rotor.
AND...You will most likely need a hubcentric ring. A washer like thing that will fill up some space on the hub. If you do not have it, the tires will wobble like they are in need of serious balancing.
Hope this helps.
Old Dec 16, 2009 | 12:38 AM
PhilfromPA's Avatar
300E 3.2
Anyone?
19x8.5 is going to be tight for sure, you'll need the offset of the wheels to confirm, and to figure out what spacers you'll likely need. As others pointed out getting an agressive sized wheel is going to require both effort & more cash on your part for a diminished ride quality.
IMO I'd sooner go 18x8, than worrying about the hassles of the 19x8.5 unless you are prepared to swap spring pads, buy spacers, etc.
Old Dec 16, 2009 | 03:04 AM
Vaicake's Avatar
1995 C280
Alright, Just curious. Cause I liked the way those rims looked.. but I didn't know if 19"s would fit.. 17(f) 18(r) is what I'd like to do..
