1995 C280 WINSHIELD FLUID RESEVIOR
1995 MBZ C280
MINE LEAKS... I FILL IT UP, IT WILL DRAIN OUT WITHIN AN HOUR. IT LEAKS RIGHT AT THE POINT WHERE THE HOSE GOES IN FOR SENDING UNIT/PUMP... ALSO.. EVEN IN THE HOUR THAT IT IS FULL... MY WIPERS TURN ON BUT WILL NOT SPRAY FLUID... ITS PISSEIN ME OFF CAUSE I CAN HEAR THE MOTOR MAKIN NOISE UNDER THE HOOD WHEN I PUSH IN MY LEVER... IM CURIOUS AS TO IF THE LACK OF PRESURE BECAUSE OF THE LEAK WOULD PREVENT IT FROM WORKING? ANY HELP IS APPRECIATD
THANKS
KEN
KEN
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
If it really is the pump, those are easy and cheap to replace yourself.
Make sure the drain is not due to the shrinking of the little black grommet down toward the lower front edge of the reservoir.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
THANKS
KEN![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
KEN
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
1995 MBZ C280
1995 MBZ C280
any more suggestions would be appreciated..
thanks
ken
