Rear Flexible Joint Disc
Old Jan 13, 2010 | 04:06 AM
yuri's Avatar
just want to share my experience....your C Class has a wierd sound ? its sound like "cling..cling.." from under the rear seat , and it comes when you just move from neutral to 1st gear...it may because of your Rear Flexible Joint Disc has tear or worn just like mine.(see the picture).
I just change it for USD 37,5 for part and USD 10 for services , and the sound now disappear......what a relief....
Old Jan 14, 2010 | 02:30 AM
rfoo's Avatar
1994 C220
Now that's one messed up flex disc. How long was it before you had it changed? I've never seen something as messed up as the one you have. I had mine changed with just few cracks on the rubber but nothing as bad as the one you had.
Old Jan 14, 2010 | 03:42 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
I had replaced one on a W202 car with about 200k miles on it. It was coming apart so much that it was beating against the bolts and had worn about half-way through 2 of them. These things are definitely something that people should check out if they are doing alot of their own work..
