W202 Cold start problem
I changed plugs (it has almost 100,000 miles on it), and mechanic friend suggests it may be the ambient temperature sensor at fault: if it is malfunctioning the engine computer does not sent a cold-start enrichment signal to the fuel delivery system, as he says.
Can anyone confirm this and, if it seems to be the case, tell me (my mechanic) where to find the sensor and test it?
New observation. I now note that if I turn on the ignition, i.e., so all the dashboard lights come on, and wait (long enough to fasten my seat belt) and then turn the key to 'start,' it starts without trouble. This suggests that fuel delivery is faulty on immediate cold start but that leaving the key on (and presumably starting up the fuel pump) allows for fuel pressure to rise to starting level and give no trouble. Any comments? Suggested remedies?
he cold start sensor should not be affected by the wait time while you are buckling up, but fuel pressure can.
