Power Antenna / Rear Window Defroster
Neither of mine are working. Fuses are good. Blinkers and all lights work fine. The only other issue is the ABS light which I'm having codes pulled tomorrow.
1. Is there a relay that controls the antenna and rear window?
2. Could an underperforming alternator cause these issues? If so I may go to Autozone and have my alternator checked and save myself $98 bucks for the ABS scan.
__________________
1996 C280
__________________
1996 C280
Doesn't that car have a fuse on the over voltage protection relay? Also, if you have a K-40 relay, that might have the bad solder joint problem. Search the archives if these issues are unfamiliar territory to you.
