ECU Reset / Turn of ABS Light
Anyway, Is their anyway to reset the ECU? I've tried fuse #32 and the battery thing. Will I have to go back and have them turn off the light with their computer?
1996 C280
1. Turn the key to the second notch (you know, where all the warning lights go on, but the car isn't started).
2. Press the gas all the way to the floor, past where you think it will go. There should be a click, which is the "quick downshift" being engaged.
3. Hold the gas like this for at least 7 seconds.
4. With the gas still pressed, turn the key to off (but don't remove it!)
5. Wait about 3 minutes without touching anything. Don't open the door, don't turn the key. Nothing!
6. You might hear a faint click noise come from around the display cluster.
Anyway, if you did it properly, the ECU should be reset. It does work on my car, but I'm not sure if it will for the 96 model. If not, look around, there might be another way.
Cleaning the wheel sensor didn't work. I checked it with a mulimeter on the OHM setting and it had no continuity.
I ordered a new one from PartsGeek (very fast shipping, will use again). I replaced the wheel sensor and started the car. ABS light came on immediately
.BUT, after taking it for a test drive the light went out after about a tenth of a mile!
So it turns out the Computer didn't need to be reset, it found the new sensor on it's own!
Cheers
