1995 C220 Speedometer
Old Mar 20, 2003 | 06:31 PM
JPlishk's Avatar
I've been having persistant problems with the speedometer on my 95 C220. I recently had the whole instrument panel replaced and the speedometer still doesnt function. Has anyone else had this problem and if so, how were u able to fix it?
Old Mar 20, 2003 | 10:18 PM
Mercedes Tuner's Avatar
99 C43 AMG & 2008 Corvette 1LT Z51 LS3
1 thing you should also look for is if the Mileage keeps going even when the speedo stops. This would indicate a bad speedo.
I believe that the Speedo signal comes from the left front wheel speed sensor and that may need to be changed. There are also a couple of fuses you should check for the insterment cluster.
Also, for some odd reason they decided to send the same wire to the back of the radio, and its possible that if your radio doesn't work that it could cause the speedo to also not work.
just a few ideas.
I'm also having an intermittent problem with my speedo and have been looking into this lately and have yet to find the problem.
