c280 taking long to start
I just remembered, there is a test u can try. Turn the key to the 2nd position (the one where all the dash lights are on) and wait for the fuel gauge needle to move up. Then turn it off. Now do that once more and then try to start the car. This little procedure gives the car a chance to get everything primed. If this method always gets the car started (without using the gas pedal) then that's another reason I'd try changing the fuel filter.
If your fuel pump is bad, you'll have a better idea after the filter is changed.
I need to get under the car and find the filter and check it out. I wish thing were easily accessible -
