Fuse Locations Please Help
1 Post
1999 C280 Sport
My wiper has stopped working and I have checked fuse #22 and it is good. There ar also some corresponding fuses #41/43 and 44. They are suppose to be in the trunk but the only box I can see has fuses # 1-10 or so. Where would the #41/42/and 43 be located?
Car is a 1999 C280 Sport![word](https://mbworld.org/forums/images/smilies/werd.gif)
I have a 1995 C180 and i am trying to find the pic of the rear fuse box on the net and a pic of the trunk and wiring in the back. sadly i wasnt able to find any. i am trying to stop someone on the street to ask him but no luck until now.
can anyone kindly assist a couple of pics would be great.
thanks.
thanks.
Maybe this will help. It's from my 2000 c230 kompressor.
The fuses are in two locations.
1. the main fuse box is under the hood and all the way on the upper right (close to the hinge location). It's an unmarked black box with a latch. I attached a picture. Ignore the blurred out stuff, those were annotations I made for a different issue.
2. The secondary fuse box is located in the trunk to the left of where the tire is. So right next to the battery.
Keep in mind that the fuse numbers you have may be different than mine and some of the slots will be empty. The fuse boxes were designed to accommodate more circuits than may be in use.
If you're still having issues and you are sure the fuses are fine, then there may be an issue with the stalk switch itself.
Do you have the Fuse diagram for the fuses in the trunk and in the upper box? This is the fuse Diagram for the lower Box underneath the hood, I need the fuse diagram for the upper box.
Please, and Thanks you!
