Changing Blower Motor on 95 C280
I am hoping that I don't have to take the dash out.
Thanks,
Tad
The first thought that I've got, though, before you drop the $250 for the motor is to check the cabin filter-- a clogged or even just dirty one could impact the performance of the motor.
As for changing the motor, if you've ever changed the cabin filter, you'll know where its located. If not, look on the passenger front side footwell. On the left hand side of the footwell, there's an air vent. Remove that. Then, on the top of the footwell, there's a large plastic panel that you need to remove. It has three phillips screws that you need to take off to get this panel off. After removing this panel, look up (a flashlight might help). There should be two compartments that are secured by clips. the long skinnier one is the cabin filter. (BTW, it might be a good idea to change this at the same time that you change the blower motor) The squarish one is the blower motor assembly. unclip the cover, and there's the blower motor. It unscrews (I think that there's 4 torx screws, but they might be phillips) and there's a single electrical connector that you disconnect and there's your motor.
Good Luck,
Eric
It is making a high pitched noise now that is even more annoying than the hiss from the crappy becker radio.
Thanks for the help,
Tad
-Tad
http://202tech.mkosonen.com/howto/blower.html
