rough idle and check engine light
Old Apr 15, 2010 | 02:23 AM
msquared9094's Avatar
1999 C230 Kompersor
I accidently put the lowest grade gasoline in my 1999 C230 Kompressor. The check engine light came on and the engine has been been running rough. It does not always start on the first time I turn it on. I have since put several tanks of premium gas but the engine still runs rough and the check light is still on. Any suggestions?
Old Apr 15, 2010 | 10:23 AM
wammer23's Avatar
1995 S420 Black/Gray
take it to Autozone or similar auto parts store and have them scan your codes (free). the code may lead you in the right direction
Old Apr 16, 2010 | 04:19 PM
tractorcrusher's Avatar
1999 Mercedes C230, 1997 Lexus SC300 Twin Turbo
Did the check engine light come on during the time the low grade gas was in the car? Sounds to me like you may need a new MAF, which is super easy to install. That fixed my rough idle and turned off the CEL.
Old Apr 17, 2010 | 10:06 PM
rfoo's Avatar
1994 C220
Easy to fix but an expensive one.
Old Apr 18, 2010 | 03:03 AM
vincesgfv's Avatar
SL 500 SP & C 280
IMO your oxygen sensor are out last time my 99 c280 got check engine light on my mec. replace the two front oxygen sensor the problem gone.
