Turn Signal Failure
2000 C230 Kompressor
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
I recently lost my right turn signal driving down the interstate (one of the plastic clips was broke) and had to buy a new lense. Well as you know when you have a blown bulb or a missing one, in my case, the turn signal failure kicks in and it flashes faster on the side with the problem. Well I replaced the lense and bulb, but it still flashes rapidly. I don't know what is wrong. I tried replacing the bulb that came with the lense with a new one and the one from the driver side (which works normal), but it still flashes rapidly. What could be the problem and a solution to fix it?
Any suggestions are greatly appreciated.
Thanks,
Michael
Thanks,
Michael
I have located the problem and fixed it. The car was previously wrecked and the mechanic got the wiring backwards when he was fixing the turn signal. I rewired it and now it is working fine.
