97 c280 help
Old Jun 6, 2010 | 03:03 PM
jonathanfrier's Avatar
97 c280
97 c280 help
i just bout a 97 c280 the problem its having is it real hard to start when its cold onece i do get it cranked it runs great after it warmed up it will crank but u have to press the gas pedle to get it to crank up also i was just messing with things and it seems to ceank up better if u unplug the cam postion senor and it will run with out it pluged in is this supost to be like that? any help will be greatly apprciated thanks
Old Jun 7, 2010 | 09:00 PM
rfoo's Avatar
1994 C220
For the hard starting, check your pressure regulator. It might need changing, hope that work out well for you.
Old Jun 7, 2010 | 09:12 PM
97 c280
how do i check it? do i just replace it?
Old Jun 13, 2010 | 10:45 PM
rfoo's Avatar
1994 C220
Yup, that's the only way you would know. Try consulting with a mechanic first too if you want to be sure. Cause where I'm from, I can ask them to put the part and see if it solves the problem, if not then I don't have to buy it. Ofcourse, not all parts are allowed.
Old Jun 17, 2010 | 12:41 PM
97 c280
ok well i replaced the fpr and the cam sensor and no diffrence the po is saying that the ecm is bad but i,m not sure one more thin i wanna know when the key is on and the car is not running i can pull the intake tube off the throtle body and when u press the gas pedle all the way down its only opening a lil bit its not opening all the way up is that normal when the car isnt running?
Old Jun 17, 2010 | 10:42 PM
rfoo's Avatar
1994 C220
it could be the throttle cable is stuck or too short that's why it won't open all the way, or throttle body is bad.
Old Jun 17, 2010 | 10:44 PM
97 c280
yeah i was wondering bout the tb cuz it dont have a cable running to it i think its called drive by wire or something like that
