W202 lowering help!
you will definitely need camber kits to correct the toe ins and outs once you've installed the lowering springs.
the costs of labor for that around here is a bit over $80 but definitely lower than a $100 including wheel alignment.
as for the ride, it's a bit stiff but the handling greatly improved and lessened sway, pitch and roll.
happy lowering.
The only problem with the stock shocks is that when you hit a sudden unpaved road my tires will rub on the fender, but besides that, no other issue.
