C230 kompressor TIMING HELLLPPPP!!!!
Old Dec 4, 2010 | 11:02 PM
juanvazquez's Avatar
mercedes c230 kompressor
I was wondering if anybody can tell me how to do the timing on a mercedes c230 kompressor, because it doesnt make much sense in the book.\
Note: i did it by the book but the engine wont turn.
Old Dec 11, 2010 | 11:52 AM
u001elg's Avatar
2006 ml350
What do you mean by "doing the timing"? The C230 Kompressor timing is done from a crank trigger and the computer and is not adjustable (i.e. no distributer).
If you don't have spark at all 4 sparkplugs, then check crank trigger and primary wiring to coils. If primary wiring is OK then, check coils...
If you do have spark, then make sure that coils and wires are at correct cylinders - but it is hard to get that out of order since there is not enough wire to easily swap the coils and the spark plug wire positions.
Keep us informed as to how things are going.
