Trustworthy & competent San Diego MB Mechanic?
Old Dec 10, 2010 | 06:30 PM
T-Roll's Avatar
2001 E55 AMG
Hello - I just moved down to San Diego and am looking for a trustworthy and competent Mercedes mechanic. Does anyone have any recommendations? Thank you.
Old Dec 10, 2010 | 07:47 PM
RANDY_P's Avatar
1996 C36 AMG, 1970 LeMans Sport, a truck
If you don't mind a drive to Riverside Co this guy is good.
Name: Baliani Automotive
Street: 26450 Jefferson Ave
Murrieta, ca 92562-6950
Phone: (951) 696-0665
Fair and good. He hooked me up when my Flex discs blew up...Great to work with.
Old Dec 11, 2010 | 03:03 AM
Tony_AMG's Avatar
1999 C43 AMG
I can recommend my coworker [Certified Star tech] but were here in Los Angeles. if you can drive up north a couple of hours then it would be much better than going to a dealer who will rape you $$$ wise or find one nearby SD area. Second if you are taking it to a mechanic, that is a problem, A mechanic only seeks possibilities of problems that may be wrong with your car, thus guessing after guessing until you have been taken for a ride and robbed of money "He tells you a filter is a proble, 2 weeks later same problem, guesses and says it's the pump" then again and again. A Technician seeks and finds the problem with your car and gives you an accurate [99.9%] assertive answer and does know what he is doing with your car using a Mercedes SDS. If you go to a dentist to see your throat infection and he tells you need to have your wisdom teeth pulled and maybe your tonsils removed, same thing goes with your car.
