abs lights and light out light
Old Dec 12, 2010 | 12:04 PM
Outlawlatemodel's Avatar
2006 c230
hey guys on my 98 c class the abs light is on read codes and says no codes
when i turn on lights the bulb out light is on but no bulbs are out, any ideas, Thanks
Old Dec 25, 2010 | 10:52 PM
99MBSport's Avatar
1999 C280 Sport
Have some one step on the brake and look at the high brake light in the rear window. I had 1 bulb out and that was the problem
Old Dec 26, 2010 | 09:11 AM
Tony_AMG's Avatar
1999 C43 AMG
check your rear lights like 99MBSport said, sometimes they deform and the housings get melted, but can be easy to fix or replace. Also Check you low beams, high beams and fog lights.
Old Dec 27, 2010 | 08:05 AM
maksi's Avatar
2020 GLC200 (X253) 1995 mb W202 C220, 2008 Mitsubishi Lancer Evolution, 2014 Ford Mustang 5.0
i also had the similar problem but it did not register an error on the diagnostics or even in the computer, had no brake lights. i checked the fuse and nothing was wrong with it.
finally decided to check my brake light switch underneath the dash and found out that it was toast. had to replace it with a new one.
funny thing is it did not registered on any of the diagnostics even in the computer. the technician said that my car was a manual / stick shift that's why it did not appear on the com and cluster.
Old Jan 6, 2011 | 12:44 AM
2006 c230
hi guys here it is the update
brake lights work fine but abs esp lights are on, put brake switch in lights stay on, wtf
