Extra noise when cold
Old May 3, 2003 | 05:02 PM
richp's Avatar
1994 C280, 2002 E320
My '95 C280 just started making a lot more noise than usual first thing in the morning (cold). It sounds like the auxillary fans are on, but they aren't. After it warms up for 5 - 10 minutes, it goes away.
Someone mentioned it may be the air injector fan. What's that?
Anyone been thru this one before?
Old May 3, 2003 | 08:58 PM
J__'s Avatar
J__
2012 C200 CGI
its normal the car does taht to warm itself up
Old May 4, 2003 | 03:19 AM
richp's Avatar
I've had the car for about 5 years and the noise its making isn't normal. It always has been a little louder when cold, but this is loud.
Maybe this air injector fan is going bad, but I can't even find it. I hear the noise around the front of the engine. I've changed the water pump before so I know my way around the area. Is it electric?
Old May 4, 2003 | 05:30 AM
Koolvin's Avatar
could be your water pump bearings ie.. replace waterpump.
Old May 5, 2003 | 01:50 AM
harrysoe's Avatar
C200 Dec'99
I have similar problem with my C200. My mechanic told me it is due to the hydraulic valve tappets. It is normal when the car is cold, especially after a few days not running. The other possibility is the auto belt tensioner inside the idler pulley. I have replaced mine twice . Hope it's helped. Bye
