Tranny problem.... I think???
Old Jan 13, 2011 | 09:10 AM
spoose's Avatar
964 C2, W202, Audi B8 Avant
Got into my 00 230k Sport last night and noticed a rattling coming from the back end at idle. Thought it might be a loose exhaust hanger. When I got home I put the car into park and the nosie went away. I get the rattle in reverse and drive at idle. Underload (accelerator pressed) the noise goes away and in park or neutral. Anyone know what this could be? Is it an expensive fix?
Old Jan 13, 2011 | 09:16 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Motor or tranny mounts.
Old Jan 13, 2011 | 10:43 AM
benz rider's Avatar
Also, check the flex discs while you're at it, look for cracks around the holes and chunks missing. they could be going bad too.
Old Jan 13, 2011 | 03:48 PM
spoose's Avatar
Do I feel dumb..... Got the car up on the hoist, turns out its the heat shield near the front rattling when in gear. Didn't think there was that small a gap for when in gear and when not. Thanks for the responses.
I think I should check the motor mounts and tranny mounts soon. Car has 185k on it and they have never been changed. Can anyone recommend when they should be done.
Old Jan 14, 2011 | 08:55 AM
C43AMG's Avatar
Veteran: Army
Every 50-75k mile ..I believe.
Old Jan 14, 2011 | 10:42 AM
spoose's Avatar
Wow, way over due. Will have to inspect those once the car is in the air. Thanks C43AMG.
